CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
oil leak
Old Aug 27, 2011 | 12:44 PM
tigerman's Avatar
Unhappy oil leak
ok so im new to the ds 650 & first off wanna say WOW this is a bad *** bike.
that being said i have an issue withe oil spraying out of the vent hose that is on the bottom of the crankcase on the right side. can any body help me with this please?
it is a 2002 ds 650 all stock
thanks
Old Aug 27, 2011 | 02:09 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Does your crankcase vent hose route up and around into the snorkel tube under the tank cover? That's where it's supposed to be and it recycles the vapor back through the airbox where it is filtered and heads back through the carb.
Welcome to the forum.
Old Aug 27, 2011 | 02:40 PM
tigerman's Avatar
yes that's where it is routed to but there's quit a bit of oil that comes out & its all over the carb and top of the motor. could there b a prob or is this normal?
Old Aug 27, 2011 | 02:55 PM
aceisback's Avatar
Military Rider
I'd recommend that since you just got your DS that you pull that tube off, flush it really well with carb cleaner, clean the rest of the blowby off of everything, and then keep an eye on it. Oil does build up in there over the years and you may just be riding it enough to blow some of the build up out. If it's still what you deem excessive after a while then do a compression check. Might be time for some piston rings.
Old Aug 27, 2011 | 06:38 PM
tigerman's Avatar
Ok I'll try that thanks I appreciate the help this site is awesome
Old Aug 29, 2011 | 04:01 PM
pipelayer's Avatar
I'm a Plumbing contractor and I have some old friends that always called me Pipelayer for some reason?
make sure the line comes out of the crank and goes up with no trap in it if it goes down then up sometimes oil will build up and plow out all of it at once making a big mess.
exmotocrosser
Sep 13, 2019 06:12 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
