since kymco makes arctic cat so i am asking this here
Old Aug 28, 2011 | 02:47 PM
bbruno's Avatar
Default since kymco makes arctic cat so i am asking this here
I have a kymco mongoose 250, will start and run but will kill if given any gas it kills,. I cleaned the carb, tank and valve, filter, even swapped carbs with another kymco that was known good so I eliminated the fuel system, then changed spark plugs, checked compression. I bought a spark tester and watched the spark and it will get weaker and die with the slightest increase in rpms. before I started checking I just wanted a little input as to the most likely cause of that might be or to get some ideas. coil, pulser coil?
Old Aug 28, 2011 | 08:27 PM
Williebee's Avatar
Post since kymco makes arctic cat i am asking this here
Welcome to the forum bbruno , kymco does make the small ac model's now up to the 366 quad's , from the 400 up are made by Suzuki and Arctic Cat's own factory ; as to your problem it could be your throddle free play adjustment , this adjuster is located on the right handle bar .
There is a rubber boot you have to slide down to get to this adjuster , there is a plastic **** to loosen to do the adjustment , then you can either turn the cable adjuster left or right to loosen or tighten the free play ; free play should be from 1/4 to 1/8" inch i've seen this problem on the larger Cat's so it should be the same on the kymco's as well .
I hope this help's you get the 250 going , this is the only thing i can think of for now , if i'm wrong someone who has experious with the electrical problem's you asked about !
williebee......
Old Aug 28, 2011 | 08:31 PM
bbruno's Avatar
its definately something in the ignition because I am losing spark
Old Aug 28, 2011 | 09:12 PM
scootergptx's Avatar
Supersock
Hired Gun!
I'll try to dig up my old service manual and see what it says. Would be for an 06 model, but that may be of some help.
Old Aug 29, 2011 | 09:02 AM
bbruno's Avatar
its either an 05 or 06
Old Aug 29, 2011 | 09:04 AM
Supersock
Hired Gun!
Check you PM.
Bratman2
Aug 6, 2022 01:42 AM
Nazz26
Jul 30, 2015 11:51 AM
Bratman2
Jul 25, 2015 07:16 PM
Club News and Events
Jul 23, 2015 02:04 AM
Gtsordo
Jul 13, 2015 10:38 PM
