dead battery
Welcome to the forum! First off charge the battery(make sure battery connections are tight!) and crank machine,check charging at the battery while running,should be 14-14.5 volts. If showing only battery voltage or lower check at the front of the atv by the radiator for the regulator/rectifier. Check that all wires are plugged in. The red wire was a problem on this model for coming unplugged! If all connections are good, then 9 out of 10 times the reg/rectifier is bad.If charging is good,then you could have a "bad" new battery(can and does happen) OPT
cody500ho
14
Aug 14, 2015 05:03 PM
