Bombardier Trax Max, 2003
Old Sep 11, 2011 | 02:28 PM
olefin's Avatar
Default Bombardier Trax Max, 2003
Having a problem with engine idle. Have to run higher RPM to keep it from dieing. Sometimes after running for half hour or so problem gets better. It just doesn't seem to be running right at low speeds.
Only has 250 miles.
Anyone have suggestions?
Thanks
Old Sep 26, 2011 | 02:49 PM
olefin's Avatar
Anybody here?
Old Sep 27, 2011 | 12:13 PM
Doctorturbo's Avatar
GOT BOOST!
I have the same quad as you.
Sounds like you need to take the carb off and give it a good cleaning.
One thing you might try is to give the gas tank a good dose of SeaFoam carb cleaner. I have not had very good luck with this stuff but it's worth a try for 5 bucks or less.
Old Nov 8, 2012 | 01:20 PM
olefin's Avatar
I gave it an oil change, then problem went away.
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
greg86hd
Sep 16, 2015 12:32 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
Hw00d
Sep 10, 2015 08:53 AM
chewy78
Sep 8, 2015 10:37 AM
