Bombardier Trax Max, 2003
Having a problem with engine idle. Have to run higher RPM to keep it from dieing. Sometimes after running for half hour or so problem gets better. It just doesn't seem to be running right at low speeds.
Only has 250 miles.
Anyone have suggestions?
Thanks
Only has 250 miles.
Thanks
I have the same quad as you.
Sounds like you need to take the carb off and give it a good cleaning.
One thing you might try is to give the gas tank a good dose of SeaFoam carb cleaner. I have not had very good luck with this stuff but it's worth a try for 5 bucks or less.
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
greg86hd
Sep 16, 2015 12:32 AM
