Idled 2000 DS650
If it's been sitting untouched for that long, I'm sure your battery is shot. That would be the first thing to look at. You could try to trickle charge it first but if the battery is weak it will not start. Than oil change and oil filter replacement.
Check your antifreeze. Replace the plugs. Clean the air filter real good. Drain the fuel tank completely. Than you should be up and running. Good Luck.
Depending on where it was stored, all the grease in bearings and bushings is probably dried up and hard. At minimum, grease all the zerk fittings. You might want to pull the axle and check the rear axle bearings and repack/replace the bearings.
Completely flush the brake fluid with new from a unopened container. Replace the antifreeze rather than just check it. Pull the carb, and clean with carb cleaner and blow out all the passages.
For what it's worth.... I helped a friend start a small block chevy that had been setting for 5+ years out in a field. We pulled all the plugs, spured about a capful of Marvel Mystery Oil into each cylinder and let it set overnight. We cranked it over with the plugs out for 10-15 seconds before putting the plugs back in. I would use about a half capful or less in the Bomb cylinder.
Pretty sure that I drained the carb by shutting off the fuel and running it until it died so that should help some. I do that with anything that could be sitting a while and has a fuel shut off, it seems to help the next time I fire it up.
Njrider1230
Jul 29, 2023 05:16 AM
tank10rnk
Aug 10, 2015 08:19 PM
