2006 - 500 fis 4x4 charging issue
Old Sep 21, 2011 | 06:24 AM
BackBreaka's Avatar
Default 2006 - 500 fis 4x4 charging issue
Hi All,
having some electrical issues.... last year my dash was taken out by rain because of a seal leak. i had a battery issue also which i replaced with a new one. i determined that my regulator wasnt charging my battery so i replaced that also. i am still having charging issues and i wonder if it has anything to do with my dash being a problem. what happens with my dash is when i turn on the key it will light up....then the led display show for about 5 seconds then it goes blank, but it still has the back light on. could this be causing my charging issues????
thanks
Old Sep 24, 2011 | 11:31 AM
BackBreaka's Avatar
ok an update or additional questions......
can someone tell me the output that the rectifier or regulator should be putting out at its cable ends??
I know if it is working correctly is should read 13.5 - 15 volts on the battery.
before the regulator the magneto/stator is showing at idle 40 ac volts and at higher rpms it goes to at least 60 ac volts
after the regulator at the wire ends I get a reading of 2.5 - 4 dc volts pending on idle or higher rpms.
thanks for advice....
Old Oct 25, 2011 | 09:36 AM
BackBreaka's Avatar
can you by pass the wiring harness and hook your charging system directly to the battery? what i am thinking of doing is connecting to the dc side of the regulator bypassing the harness wires and hooking direct to see if there is a problem with my harness??
is this feasible? recommended?
any comments would be helpful
thanks,
velcro7279
Aug 24, 2015 01:15 PM
cody500ho
14
Aug 14, 2015 05:03 PM
baysport
Jul 23, 2015 11:37 AM
200es
Jul 19, 2015 04:50 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
