New replacement pulse generator only has a place for one wire old one has two!!!!!!!
Old Sep 21, 2011 | 06:22 PM
Big "T"'s Avatar
Default New replacement pulse generator only has a place for one wire old one has two!!!!!!!
I searched the internet and this site as well as others but I found nothing on this problem. I have a 86 TRX250 fourtrax. I bought it not running. replaced CDI, Coil, and spark plug. It ran good for a few weeks and quit. I did the electrical checks per manual and the pulse generator is a little out of spec. I ordered a new one online and when I received it, It only has one male spade connection and my old one has two round barrel connections. The new part is a replacement part for several pulse generators of that era. I need to know how to rewire the two wires. One is blue with yellow stripe and the other is green with white stripe. My guess was the blue w/y is the main one that will go to the spade but I don't know what to do with the green w/w wire. One thing to add, after I took the side case off, I looks as though the starter gears had came loose at one point in time and nicked the flywheel up a bit on the outside and the little tab, I filed the burrs down. It didn't have any starter gears in it when I got it??? Any help would be greatly appreciated. Thanks in advance for the help!!! "T"
Old Sep 25, 2011 | 04:30 PM
Big "T"'s Avatar
Is this question posted correctly? Is it in the correct place? I'm new at this and not sure what I'm doing!!!!! Thanks
Old Sep 25, 2011 | 05:29 PM
user493's Avatar
Moto Psycho
Welcome to the forum. Try posting in the Honda section and hopefully you can get some help. Good luck.
Old Sep 25, 2011 | 08:56 PM
Big "T"'s Avatar
Thanks!!
Old Sep 25, 2011 | 10:19 PM
user493's Avatar
Moto Psycho
You're welcome.
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
jag6510
Jun 15, 2015 05:59 PM
FWhitt
Jun 13, 2015 02:22 PM
Chawness
Apr 21, 2000 08:14 AM
