little problem
Old Oct 17, 2011 | 07:16 PM
boulterboy's Avatar
Default little problem
I have a 99 500 sportsmanits leaking coolant out of the water pnmp it looks like there is a little whole under the pump housing is the just a plug missing or is it time for a new housing
Old Oct 17, 2011 | 10:59 PM
Welcome to the forum! Sounds like you need a new water pump seal. The hole is there for a purpose,to indicate when a coolant seal or engine oil seal has started leaking and needs replacement. You need a new seal and gasket and people have changed these out WITHOUT the special tool that removes the seal,BUT damage to the shaft can happen which would result in much more $$$ in repair costs! The tool the last time I checked was around $75 dollars. Plenty of videos out there showing how to do it( the wrong way!) some the right way!
Or you can have an authorized dealer do it,usually for about a 2.0 hr labor charge plus parts.The choice is yours. Good luck OPT
Old Oct 18, 2011 | 08:58 AM
boulterboy's Avatar
thanks
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
