Could I change the front differential in my 2000 Big Bear 400 4x4?
Old Oct 18, 2011 | 05:25 PM
NYH1's Avatar
Default Could I change the front differential in my 2000 Big Bear 400 4x4?
Could I swap my 2000 Big Bear 400 4x4 "full time" 4x4 front differential for a 2002 or newer "selectable" 4x4 differential? Is there a way to make it work correctly in my four wheeler?
Thanks, NYH1!
Old Oct 31, 2011 | 05:00 PM
NYH1's Avatar
Anyone??
Old Oct 31, 2011 | 07:55 PM
95wolv's Avatar
It should be possible, but you would need the wiring harness and whatever else is involved in the selectable differential. Then you would need to confirm the gear ratios of the front and rear diffs, if they are not the same, when running in 4wd, you run the risk of "binding" the drivetrain with the front and back wheels trying to run at different speeds, which would wreck something in short order. Might be cheaper to just find a newer quad with the features you want, less work, and set up to work correctly from the factory.
Old Nov 6, 2011 | 11:46 PM
Dick-quad's Avatar
Make sure u get 1 with a diff lock,and check that the axles fit. let me how it turns out, my bro has a kodiak 400 but he needs a diff lock added to his
Good Luck
Old Nov 8, 2011 | 07:51 PM
NYH1's Avatar
I'm just kind of thinking out loud. I've seen a few 2001 and newer complete Big Bear 400 4x4 front differentials which are selectable 2x4 to 4x4 on ebay and other classifieds. I wasn't sure if they would fit in my 2000 Big Bear 400 4x4. I should have bought the Warn 424 kit when it was available. I kept putting it off and then they stopped making them.
NYH1.
neilbedwell
Nov 10, 2018 11:02 AM
WilliamBos
Sep 30, 2015 08:08 AM
Biggieshortie89
May 26, 2015 08:01 AM
CanadianViking
Feb 16, 2001 11:56 AM
