04.5 sportsman awd not working
I bought this atv with awd not working the guy I got it from said that the cage was broke in the front diff he had already bought the parts for it to fix it but he never got around to it before I bought it. I have replaced the broken cage and rollers put it all back together and nothing front end will not engage. I need some help if anyone has run into this.
First off are you getting 12 volts to the front gear case in awd mode? Also did you replace the armature plate? Also gear case was changed after 7/13/2003 build date and shows different part numbers for the cage and armature plate.Did you have the correct parts for the build date of your machine? OPT
whitty
67
Feb 24, 2021 02:52 PM
chuck1177
Jun 30, 2015 09:52 AM
