04.5 sportsman awd not working
Old Oct 19, 2011 | 11:00 PM
stockcar55's Avatar
Default 04.5 sportsman awd not working
I bought this atv with awd not working the guy I got it from said that the cage was broke in the front diff he had already bought the parts for it to fix it but he never got around to it before I bought it. I have replaced the broken cage and rollers put it all back together and nothing front end will not engage. I need some help if anyone has run into this.
Old Oct 20, 2011 | 04:17 AM
First off are you getting 12 volts to the front gear case in awd mode? Also did you replace the armature plate? Also gear case was changed after 7/13/2003 build date and shows different part numbers for the cage and armature plate.Did you have the correct parts for the build date of your machine? OPT
Old Oct 22, 2011 | 05:27 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to the forum. is all the parts assembled correctly, does the bike show that is in in awd or no light saying it's enageged?
whitty
67
Feb 24, 2021 02:52 PM
Ipmcelroy
Technical and How-To Articles
48
Nov 21, 2015 08:02 AM
chuck1177
Jun 30, 2015 09:52 AM
yellowpolaris
Jun 21, 2015 11:13 AM
dunk24
May 25, 2015 05:48 AM
