Piston Failer??????????
Old Nov 7, 2011 | 05:58 PM
AtvMinibike's Avatar
Default Piston Failer??????????
I have suzuki lt80 not working.just had a look at piston.piston has scrap marks up and down it.feels rough.same with inside of cylinder.i suspect oil injector hasnt been working properly.tried a little fuel down plug hole and it fired up for about 3 seconds and that was it. please advice on what i should do.dont know much,learning as i go!!
Old Nov 8, 2011 | 07:32 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
I moved this to the kids section so LT80 can give you some advice.. Id say the piston, rings and cylinder are junk.. not sure if you need a new cylinder or if that one can be bored out.. LT80 will know..
Old Nov 8, 2011 | 05:46 PM
Thanks!Waiting for LT80 for the advice. Tinkering now trying to clean off the scrap and cleaned up with oil.
Old Nov 9, 2011 | 12:01 AM
LT80's Avatar
LT80 Expert
You will need a top end rebuild.
ie: new piston/rings and bore to match.
I allways use a new piston pin, pin brg, and cir-clips.
We would need to figure out what size your cylinder is on. You see what is in the top of your piston.. .0 .5 1.0
You can go to:
Ohio Motorcycle ATV Dealer - North Ridge Yamaha Suzuki - Geneva, OH - Scooter Utility-vehicle, snowmobile
And look at the parts fiche. Seeing the parts blowup can explain alot.
I have a few cylinders being freshened up and will be for sale very soon.
This may be something your interested in.
Surely there is a local guy wherever you are that can help also.
Hope that helps.
Old Nov 9, 2011 | 07:01 PM
does the piston coating ensure that the ring remained undamaged under intense mechanical forces? a friend recommends a hardier coating.
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
