2001 Eton 90cc help...
Old Nov 22, 2011 | 11:20 AM
atalvis's Avatar
Default 2001 Eton 90cc help...
I have a 2001 Eton 90cc four-wheeler. It has loss of power, will not accelerate, will idle, engine sounds like it is laboring when throttle is full. Please help... Thanks.
Old Nov 23, 2011 | 08:05 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
I allways start with a good carb cleaning.
Then I'd do a compression test (100-120).
If both those are good, I'd get into the clutchs to inspect for a problem.
Old Dec 29, 2011 | 04:16 PM
Thawkins5443's Avatar
Default Same problem here with my '02 Eton DXL 90--No power at all.B
I have replaced the carb; compression test at 120 psi; good fuel flow. Will a clutch problem prevent it from gaining RPM? What is the fix?
Old Dec 30, 2011 | 07:12 AM
JTolliver's Avatar
No revs with no load? Have you checked the exhaust?
Old Jan 1, 2012 | 10:00 AM
Oldsman67330's Avatar
could be fuel in the crankcase, plugged muffler, bad crankshaft seals or problems in the clutch housing. I had a Yamaha 125 doing that one day....pulled the belt cover and found the clutches and belt housing to be packed full of rabbit hair....freakin' mice!!! It took me 3 hours to get all of that stuff out of the clutches and starter mechanism.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
