More power out of Sportsman 500
Old Dec 24, 2011 | 05:36 PM
sportsman09's Avatar
Default More power out of Sportsman 500
Need some more info on some things I can do to my 500. Not worried about top end power looking for more low end power. Any one have good results with anything? Thanks
Old Dec 24, 2011 | 11:18 PM
Oldsman67330's Avatar
I always thought my 500 scrambler was a dog, I put a DG slip on pipe on it, dynojet kit, K&N filter, reworked the drive clutch, whole different animal now. You are probably fuel injected with an '11 machine, so the dynojet kit won't help you much. I have a buddy we ride with who bought an '11 550 sportsman and thought he could take me drag racing...he thought wrong. I'll take him out in mud, sand or dry ground, 2x4 or 4x4.
Old Dec 25, 2011 | 11:47 AM
Spdecat's Avatar
Install a AAEN kit stage 1 to 5 Aaen Performance - Polaris ATV 500
Old Dec 25, 2011 | 12:23 PM
Kerbbirds's Avatar
can change spring in primary clutch, they come with a blue, change to white fo a little more bottom or buy a green for alot more, everything you gain on bottom you will lose on top, the green will probably cost you 5-7 mph, springs are only like $20 at dealer
Old Dec 25, 2011 | 01:37 PM
Are you just changing the spring? Did you do this. Hard time finding people with 500s that have done anything. Thanks alot
Old Dec 25, 2011 | 07:50 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
My 07 is EFI and I installed a Dobeck programmer and a hot seat performance slip on. The power gains and throttle response on the bottom end were very noticeable but not earth shattering. Didn't notice any difference on top end. A clutch kit or just the primary spring will probably be your biggest bang for your buck.
Old Dec 25, 2011 | 08:07 PM
I don't have efi though but might Try a spring or two. Where is the best place to get springs from? Are you running a Polaris spring or another brand? Think a friend told me Kawasaki spring are the same as Polaris springs. Not sure though
Old Dec 26, 2011 | 07:13 PM
Kerbbirds's Avatar
I had a green polaris spring in mine for awhile, it gets alittle scary in the boulder piles, clutch engages at a higher rpm and would pick the wheels up when you really didnt want to, I changed it back cause my daughter started riding it, the springs I have are polaris
Old Dec 26, 2011 | 07:23 PM
Do you get them from the dealer or online? I have been looking with not much luck.
Old Dec 27, 2011 | 12:45 PM
Big600twin's Avatar
try EPI. they have good clutch upgrades.
