1998 polaris sportsman 500 4wd wont engage
Old Jan 2, 2012 | 06:06 PM
brekke's Avatar
Default 1998 polaris sportsman 500 4wd wont engage
4wd wont engage.had some electrical issues that blew the light bulbs wondering if damage done to 4 wd? following wiring to front of machine behind the grill i see a little electrical box what is that and could that be the issue?
Old Jan 2, 2012 | 06:36 PM
Welcome to the forum! You're probably looking at the rev limiter or the regulator/rectifier(located close to the radiator). Just look under the front panel, and you will see two small connectors with grey and brown wires on each and follow these down to the hubs. You can check first if there is voltage first at the connectors in awd with the power on. Grey wire is the hot wire. Battery has to be fully charged for awd to work! Has to have 12 volts. You can always just jack up all 4 wheels and with awd on,crank and see if front wheels turn. OPT
Old Jan 4, 2012 | 06:38 PM
brekke's Avatar
ok I will try this and get back to you. what i have tried so far i dont have any voltage to the 4wd switch next to trottle took it apart and checked with volt meter and had nothing checked quickly on my way to work
Old Jan 4, 2012 | 06:48 PM
You have to be in gear(low or hi) for the switch to receive current! It gets its signal from the internal switch in the shift box,then current goes to the hub coils! This is a funky system where all things have to work properly or you wont have awd! If you don't have power to the push button,then the shift box gear position switch could be faulty! On later models (99 model and up) the gear position switch was moved to the transmission where it should have been and eliminated this problem for the most part! OPT
Old Jan 13, 2012 | 01:10 PM
brekke's Avatar
thanks for your help it was the pin in the shifter slid back and wasnt making contact thanks for help
Old Jan 13, 2012 | 03:21 PM
I've moved shift box switches up in the past, but a lot of times they have slipped back also,if it continues to do this a new switch may be necessary or shift box wear? Good luck, hope it holds up. OPT
Old Jan 13, 2012 | 03:29 PM
brekke's Avatar
ok thanks. I also have a issue with the shifter it wants to lock up periodically I unhook the linkage so I know its in the shifter took the shifter apart and cleaned it up everything seems fine it works for awhile then locks up again any solutions to that
Old Jan 13, 2012 | 03:49 PM
The solution is to replace the shift box! NOT trying to be a smart azz,but I've been down that road many times on the old shifters and have tried replacing badly worn parts all the way up to replacing ALL the internal wear parts and it's actually cheaper to replace the shift box assembly! It will shift like a new machine! $238 at Cycle Parts Warehouse,about as cheap as you can find(cheaper than the dealers) and comes complete with switch ready to bolt on. Switch itself separately is $104 and may not solve all your problems as you mentioned! OPT
bzdok1234
30
Feb 23, 2016 01:55 PM
coolguy420
Jul 10, 2015 01:17 AM
ranvette
Jul 4, 2015 06:13 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
