big bear engine swap help!!
I have a 2007 yamaha big bear 250 I bought recently for a steal it dropped a valve and previous owner took apart and lost most of parts is there another engine I could put in its place like maybe a 350 or 400 that will bolt right up? Any help would be great
I don,t think it would work. The 250 is a different motor unlike the 350 and 400 which are the exact same motor just with a different stroke. (64.5mm vs 71.5mm)
So the 250 would have different motor mount points and the rear end would have a different drive shaft positioning and size.
So I started making a big bear tracker 400 this weekend yes there's a lot to change .motor mounts the whole rear end had to be swapped I had to add 2" to the swing arm connection point. That's all I've come across so far. Just a backyard project. I want something different than everybody else and I like my bear trackers.
silverzz28
Aug 6, 2013 05:45 PM
