big bear engine swap help!!
Old 01-08-2012, 07:42 AM
lytefoot's Avatar
Default big bear engine swap help!!
I have a 2007 yamaha big bear 250 I bought recently for a steal it dropped a valve and previous owner took apart and lost most of parts is there another engine I could put in its place like maybe a 350 or 400 that will bolt right up? Any help would be great
Old 01-09-2012, 10:50 AM
TLC's Avatar
TLC
TLC is offline
I don,t think it would work. The 250 is a different motor unlike the 350 and 400 which are the exact same motor just with a different stroke. (64.5mm vs 71.5mm)
So the 250 would have different motor mount points and the rear end would have a different drive shaft positioning and size.
Old 01-09-2012, 04:20 PM
Raptor450's Avatar
You'd probably be better off to find another Big Bear engine or all the parts (EBAY!) and put it back like it's supposed to be.
Old 10-24-2022, 06:02 AM
Islandtodd's Avatar
Default Making a big bear tracker 400
So I started making a big bear tracker 400 this weekend yes there's a lot to change .motor mounts the whole rear end had to be swapped I had to add 2" to the swing arm connection point. That's all I've come across so far. Just a backyard project. I want something different than everybody else and I like my bear trackers.
Joe04785
03-11-2014 01:06 AM
silverzz28
08-06-2013 05:45 PM
TNT-Knut
10-02-2010 11:14 AM
btemefordboy
03-10-2006 08:54 PM
bk8800
09-06-2005 09:28 PM
Quick Reply: big bear engine swap help!!
