2001 yamaha breeze 125
Old Jan 10, 2012 | 09:35 AM
Spre's Avatar
Default 2001 yamaha breeze 125
I need more opinions on this, this quad had its chain bent so we got a new chain and tensioner (as this was bad aswell) got it together and it starts and runs fine, it just doesn't go when you hit the gas.
Now we took it to a local shop which charged 35.00 to look at it, took them 2 weeks, they come back with it will be 1000.00 as the crank is bent, now since it starts and runs fine, this doesn;t sound right, all crank diagrams show it is directly connected to the piston, so one would assume if it was bent it would have bad compression as it wouldn't move right, and bad compression would affect its starting and running.
So what do you think on this? I think it may just be a gear in the transmission, it has many gears and if one gear has an issue it wont in lamen terms be able to tell the gear the chain is on to "turn"
it is automatic with forward reverse and nuetral
Thanks in advance!
Old Jan 11, 2012 | 10:01 AM
Doctorturbo's Avatar
GOT BOOST!
Thanks in advance!
I'm raising the bovine feces to full staff on the bent crank.
As far as the "just dosen't go" it could be a lot of things. Could be even as simple as a broken belt. Have you even had the belt cover off and looked at it? That is where you need to go first.
Hunter100us
Oct 7, 2015 11:46 PM
ghost civic
Jul 30, 2015 04:09 PM
ghost civic
Jul 27, 2015 03:15 AM
ghost civic
Jul 15, 2015 10:48 PM
maxjung
Jul 14, 2015 03:10 AM
