Is there any way to cross reference part numbers
Old Jan 16, 2012 | 09:58 AM
ZAKAZIM's Avatar
Question Is there any way to cross reference part numbers
Hello all!! It’s been a long time since I last posted but I need some help. Went for a ride yesterday on my 2011 800 sportsman with 580 miles on it. I got this ATV 2nd hand with 210 miles and no extended warranty and the factory ran out 1 month ago. Well I got myself in a bind and had to tackle a mud hole that ended my day with a blown rear axle. The joint that plugs into the gear case just exploded under very little tork so I’m thinking it was a defect as I have never seen or hared of this. Question??? Is there any way to cross reference part numbers to see what year units it will fit??? So I can try to get one off eBay or just bite the bullet. Pure Polaris part# 220436/ 3135571 is 212.00 and up.
Old Jan 16, 2012 | 11:21 AM
Don't have a list on cross referencing numbers,but the plunging joint is $166 at Cycle parts Warehouse.
Plunging joints or cv joints can explode internally,spitting pieces out like this, if to much torque is applied to em,saw this constantly even on brand new machines at the shop.You might consider later on replacing rear drive shafts with heavier duty ones such as Gorilla or EPI if you are constantly playing in the mud. OPT
Old Jan 16, 2012 | 02:42 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i actually did the same thing to my 08' 800 on the front side axle and destroyed it. i bit the bullet and bought a new oem. polaris wouldn't warranty it anyways as they would say driver error or a normal wear item. funny how that works. if you use polaris cross ref. it's used only inthe 2010 through 2012 models being anywhere from the 400,500,700 and 800 sportsmans. seems odd that the 400 would be the same.
Old Jan 16, 2012 | 03:17 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
I'd just pony up the dough and get the heavier aftermarket axles. Try the cv man here http://www.google.com/url?sa=t&rct=j...--l6GMDw_CV1dQ
Old Jan 17, 2012 | 05:32 AM
ZAKAZIM's Avatar
Thanks all just going to get the OEM parts and fix it up. Oh I did find that the swing arm and upper A arm will need replaced also as the joint wedged itself in twistted them up also.
Old Jan 17, 2012 | 04:59 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
thats what i did for an easy install and knowing it will be right.
toonces
Aug 5, 2015 05:55 PM
toonces
Aug 3, 2015 09:59 AM
338 lap mag
Technical and How-To Articles
Aug 2, 2015 03:57 AM
JoAnnS
Jul 23, 2015 02:18 PM
