Difference between 2004 DS650 Frame and 2003
Old Jan 19, 2012 | 11:36 PM
lyricsport's Avatar
Default Difference between 2004 DS650 Frame and 2003
Is there a difference between the frame from a 2004 DS650 and a 2003?
I have a 2004 (dated 07/2003) that is in need of a new frame. Will one from a 2003 (dated 06/2002) be an exact, or even good, replacement?
Old Jan 20, 2012 | 06:11 AM
justme23005's Avatar
yup
Old Jan 20, 2012 | 07:50 AM
bartmann's Avatar
Banned
think there is only color change and subframe changes......
Old Jan 20, 2012 | 12:59 PM
DSengineer's Avatar
Has been here a long time!
No changes to the DS frame were ever made. All years are identical with the exception of paint color.
Old Jan 20, 2012 | 02:01 PM
lyricsport's Avatar
Thanks, all! That really helps.
Old Jan 20, 2012 | 06:34 PM
bartmann's Avatar
Banned
your saying all the subframes are the same ? I would disagree..
Old Jan 21, 2012 | 09:06 PM
pipelayer's Avatar
I'm a Plumbing contractor and I have some old friends that always called me Pipelayer for some reason?
Is the swing arm bolt a different size? it sure looks like it? sub frames all bolt up so if there is its just looks
Old Jan 21, 2012 | 11:21 PM
TheStir's Avatar
Started riding ATVs in 1974!
Pipe is right.
Swing arm bolt is smaller on the later DS's that had the aluminum arm. I have both style frames sitting in my garage.
The early and late swing arms have the same size bore for the bushings so you can use either frame with either arm with the bushings that match the frame bolt.
I also have late and early sub frames in the garage, they are the same but for color.
Jmuddin284
Jan 19, 2026 07:16 AM
velcro7279
Aug 24, 2015 01:15 PM
DFWSRT8
Aug 20, 2015 09:24 AM
metal249
Jul 28, 2015 09:35 AM
bpegram84
Jul 22, 2015 08:15 AM
