working on 350 4x4 help me
Old Mar 17, 2001 | 01:42 AM
Toad1167's Avatar
HELP,Im working on a friends 93 350 4x4 and it is giving me a fit.First the recoil starter spring has come undone(how do I fix it when I cant get the rope pulley off)next the starter quit working and only clicks at the selinoid,then the swing arm has a rediculous amount of play which our dealer tells him I should just tighten it up(yea right)next the front wheels lean out at the top real bad,how in the world do you fix that?Then the support bearing that runs between the rear drive sprocket and the center drive sprocket is so stuck I dont know how to get this **** thing off.I know this is alot to ask but you guys know the most so please HELP ME,thanks for any help.P.S. I'm glad my 96 400sp isnt anything like this poor old bike
Old Mar 17, 2001 | 09:07 AM
Toad1167's Avatar
come on surely some one can help with at least one of these problems.
Old Mar 17, 2001 | 10:20 AM
x_scrambler3's Avatar
Well I have never taken the recoil cover off my scrambler have you tryed undoing the the handle maybe it is like my Trail Blazers an have to get the handle off to take off cover. The bearing you are takling about you need to take the gear an the disk for the break off the shaft an then there are 2 bolts+nuts an then it should slide off. Hope this helps a little
Old Mar 18, 2001 | 03:16 PM
Toad1167's Avatar
Thank you.
Old Mar 18, 2001 | 07:32 PM
Madman72's Avatar
The only thing I can help you with is the clicking of the starter, the battery is dead. Other than that, your on your own my friend.
Old Mar 18, 2001 | 07:39 PM
If your swing arm has play in it like you can move forward an back with it then what has happend an seem to happen is the swing arm bolt has come lose an if it moves back an forth alot then it make the hole in the frame eggshaped where it bolts up. The cheapest an easyest way yo fix it is when you are looking at the frame where the bolt gose there is a washer welded on. You wil need to grind the welds an get it off. Then once off get a new washer the same size an weld it on where the old one was an make sure you put some lock tight on the bolt an nut an get it realy tight. I have done this to my TB
Old Mar 22, 2001 | 01:23 PM
Farmr123's Avatar
I think I can help with the swingarm being loose. If it is bad, likely the washer welded to the frame has the hole egged-out.
If I remember right, either a flywheel or harmonic balancer bolt washer off of a 350 GM engine is the same size as the washer on the frame, and is a little thicker than the original. Make sure you use a new bolt and locking nut, and be sure install the little plate that goes under the bolt head with the ears you bend against the flats of the bolt head to keep it from turning.
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
