Arctic cat 50cc 2 stroke problem.
Old Jan 24, 2012 | 06:09 PM
427's Avatar
427
Default Arctic cat 50cc 2 stroke problem.
I tried this in the AC section with no reply. I have around a 2000-2002 Arctic Cat 50cc quad I bought used. It is very clean and has always ran well. While driving around the yard the engine just started misfiring just as the clutch is engaging. It will not rev higher even with the rear tires off the ground. I had put a high rpm ebay ignition box on it that worked fine, but I removed that and went back to stock without helping. Has anybody ever seen a problem like this? I have cleaned out the carb and replaced the plug also.
Thanks in advance
Kurt
Old Jan 24, 2012 | 11:30 PM
LT80's Avatar
LT80 Expert
Hmmmm...
2 strokes..maybe a air leak around the intake? Spray carb claener.
Maybe the crank seals?
Maybe the pipe is plugged. Sometimes the end gets gummed up and won't let it breath.
I'd start wit the pipe.
Old Jan 26, 2012 | 07:21 PM
427's Avatar
427
Black flakes had come loose inside the pipe and plugged the tip! Thanks! Now onto my other sons LT80. I bought this one not running right....
Kurt
Originally Posted by LT80
Hmmmm...
Old Jan 27, 2012 | 08:15 AM
8687parts's Avatar
black flakes?? would this be carbon?
Old Jan 27, 2012 | 09:04 AM
LT80's Avatar
LT80 Expert
Carbon, unburnt fuel, etc..
I ""accidentally"" poked a hole in that screen.
exmotocrosser
Sep 13, 2019 06:12 AM
Beeline08
Nov 11, 2016 04:00 PM
exmotocrosser
Sep 26, 2015 08:18 AM
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
