lt 80 oil pump removal
Old Jan 24, 2012 | 10:13 PM
lt80 Dueces's Avatar
Default lt 80 oil pump removal
i got an 87 lt 80 and im wondering what steps are taken to remove the oil pump system! any help w this would be appreciated! also does removing the oil pump and mixing ur own gas really increase some power? what other reasons for doing this?
Old Jan 25, 2012 | 04:44 PM
Wildcard0413's Avatar
It's pretty simple actually. It took me longer to get the darn oil tank out than anything else.
Pull of clutch cover and remove the plastic piece on the end of the crank shaft.
Remove the two bolts that hold the oil pump on (Allen Screws)
Go to LT80 Hop-Ups and order the block off kit.
I had to remove the rear fender and battery to get the oil tank out.
Make sure you cap off the oil inlet on the carb, the kit comes with a plug.
Old Jan 25, 2012 | 06:21 PM
what r u mixing ur gas at? what do you recomend for mixing oils? so does it really increase power at all? thanks for the reply i was curious about how to block off the inlet on the carb.
Old Jan 25, 2012 | 07:44 PM
8687parts's Avatar
i just got mine running tonight after rebuild. i mixed at 32-1 but i might run a little higher next gallon mixed. seemed to smoke just a tad bit. but ran perfectly fine. wouldnt say so much of a big power gain although i took it off while doing whole build so i dont know the difference between just oil pump removal and all stalk. I WOULD say that it is just a no brainer that it puts less strain on the motor alternately giving it more power some would say
Old Jan 26, 2012 | 08:40 AM
LT80's Avatar
LT80 Expert
No more power IMO.
FYI:::
Stock = from the factory
Stalk = what you've done to get that court order against you....
LMFAO!!!!!
Old Jan 26, 2012 | 05:13 PM
8687parts's Avatar
sorry. that would be the fault of my spell check on my phone. you would love to see what some of my messeges turn out to read after I push send.
Old Jan 26, 2012 | 06:50 PM
k this mite b a dumb question lt80 but whats IMO?
Old Jan 26, 2012 | 07:38 PM
papa hogg scoot's Avatar
Loved
Community Favorite
In My Opinion!!
Old Jan 26, 2012 | 07:50 PM
lol ok thanks papa hogg scoot! that makes sense
Old Jan 27, 2012 | 09:02 AM
LT80's Avatar
LT80 Expert
Originally Posted by 8687parts
sorry. That would be the fault of my spell check on my phone. You would love to see what some of my messeges turn out to read after i push send.
lol!
Jason Richards
Sep 4, 2015 06:17 PM
Dan Newberry
Aug 30, 2015 09:42 AM
Cantbuytime
Aug 16, 2015 09:13 PM
house1
Aug 9, 2015 10:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
