HELP NEEDED 2001 Polaris Scrambler 500
Old Feb 25, 2012 | 10:50 PM
BMB31586's Avatar
Default HELP NEEDED 2001 Polaris Scrambler 500
Hey guys could you please help me I am in need of some knowledge. I just bought a 01 scrambler 500 4x4 and took it out today and rode with my uncle who also has a scrambler 500 4x4 but his is an 06. We raced a couple of times and his was faster . So my question is what is different on these two . I know his is completely stock minus a k$n air filter which mine has as well.From my understanding they are both the H. O. motors. Is there any updates that I could do to mine to make it the same speed with minor work? Any input is appreciated . Thanks
Old Feb 26, 2012 | 05:12 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
not sure if the gearing(sprocket size) would be differnt in the year models butthat could play apart as well as worn clutching and belt which would loose a little in the speed department.
Old Feb 26, 2012 | 10:06 AM
TLC's Avatar
TLC
Try a belt change, my cousin has a 2000 Scrambler 500, he changed his belt and the old belt still looked good but the new belt made the machine go from a top end of 55 to almost 60 some how.
Old Feb 26, 2012 | 12:39 PM
BMB31586's Avatar
I just put a new belt and chain on it when I bought it. I also have a new plug I need to put on as well.
Old Feb 26, 2012 | 01:49 PM
Do you both weigh the same?? If not could be a factor,plus just swap machines and see if you can beat him on his while he's riding yours You have to remember too that his machine has 5 years less wear on clutch and engine internals. We've had this question since day one at my old shop!! We've even sold machines to different friends straight out of the crate and I don't know how many times one customer would complain that his friends atv is faster than his! And I admit that some identical atvs whether Sportsmans or Scramblers,etc have been noticeably faster than others like I said straight out of the crate. No two machines are identical in every respects. OPT
Old Feb 26, 2012 | 01:52 PM
BMB31586's Avatar
Yes there ain't 15 pounds difference between us. Would a clutch kit help or maybe a jet kit? Are these motors the same or have they changed ?
Old Feb 26, 2012 | 02:06 PM
Engines are basically the same,same carb,but different part numbers for each model. Has same jetting 40 pilot,155 main jet along with clutches basically the same. There are parts that have been subbed to different numbers over the years and you know in 5 years certain things have been "tweaked out" as engineers see fit,just like cars,each model year of a certain car has improvements other than just body changes,some good,some bad. You can always do mods to beat him,but he can do the same! OPT
Old Feb 26, 2012 | 02:25 PM
BMB31586's Avatar
Thanks Polaris tech
stendori's Avatar
Super Quad Patrol
I'm watching you!
basicly you have pretty much the same. wear in tear on yours wil make a differnce and as opt pointed out what you can improve on so cvan your friend.
Big600twin
14
Jun 16, 2015 09:30 AM
hoopduerr
Jun 10, 2015 03:00 PM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
FourWheelOverTwo
May 31, 2015 07:26 PM
