Noisey Engines?
Old Feb 27, 2012 | 02:02 AM
Wilderness 250's Avatar
Default Noisey Engines?
Hello everyone. Has anyone noticed that these Chinese engines seem to be a liitle more noisey than their Japan counterparts? I just got dont going through a Wilderness 250cc from front to rear, the absolute worst things is for these atv's to sit for a long time. I was just curious as to everyone elses thoughts on the engines.
Tom
Old Feb 29, 2012 | 04:07 PM
TacticalRedneckofKentucky's Avatar
I havnt noticed that, last time i saw one i couldnt hear him over the rumble of my hmf pipe.
Old Mar 3, 2012 | 10:16 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum Wilderness 250!
I am surprised mine all still run..and run well... mine arent noisy.. but my 125 and 150's do vibrate a bit..especially my 125..
Did you buy the Wilderness 250 used?
Old Mar 4, 2012 | 07:21 PM
I bought it used and sitting a long while. I now have it running excellent except there is valve train ticking that doesnt sound normal to me. I set the valves at 4mm perhaps they need to be a tad bit tighter. This one has me stumped because i cannot see anything that is out of the ordinary.
Tom
Old Mar 4, 2012 | 10:20 PM
LynnEdwards's Avatar
Electrical Expert
I'm assuming you meant the valve clearance was set to 0.004 inches and not 4mm. 4mm is about 3/16 of an inch .
I don't know about 250cc engines. 0.004 inches (exhaust and intake) on my 150cc GY6 engine works fine.
Old Mar 5, 2012 | 12:05 AM
I guess the big question is that if the valves get to be too tight will they also tick? I guess its possible because they are working way to hard, after researching a bitI think that setting them at 4mm is indeed to tight, geez I wonder what I was thinking. Back to the drawing board I guess.
Old Mar 5, 2012 | 07:23 AM
KTM Patrol
Former Chinese POW!
Where are you checking the valves and getting 4mm of clearance?
4mm is .1575 .... 40 X as big as .004
If you have them set at this.. which i doubt..it wouldnt run.. if it did it would be very noisy.. but the valves would be very loose, not tight..
Old Mar 5, 2012 | 10:22 PM
You are correct it is .004 not 4mm. I should have made that more clear. I am wondering if they are still to tight. I thought I read on here somewhere that .004 was the setting but it may not have been for the 250's.
Tom
Old Mar 6, 2012 | 08:08 AM
KTM Patrol
Former Chinese POW!
If they were tight you would have trouble starting it..
Are you sure you are at the correct TDC when you check/set the valves? there are 2 TDC's on a 4 stroke.. you want the one after the intake valve closes.
Old Mar 6, 2012 | 11:13 PM
I agree. I will double check the settings but it starts right up and runs very good. Its just noisy in the valve area like one is loose, but based on what I am reading its not possible. I set them to .004 but the service manual I found calls for .005 intake and .009 exhaust. So I am clearly tighter than what it calls for yet the noise it makes sounds like its loose . Thats why I was asking if a tight valve also makes a ticking noise similar to a loose one but not as loud.
