my warrior 366 almost done
Old Mar 1, 2012 | 09:31 AM
beastlywarrior228's Avatar
Default my warrior 366 almost done
Chassis | Suspension | Controls
Frame: Stock
A Arms: +2 ASR Pc Candy Blue by Capital
Swingarm: Converted Roundhouse
Steering Stem: Stock
Stabilizer: N/A
Axle: G Force
Carrier: Lonestar Dual Row Billet
Locknut: G Force
Hubs F|R: Stock
Bars: Protaper SE
Throttle/Clutch Lever: Stock
Grips: Renthal
Nerfs: Pro Armor
Pegs: Pro Armor
Bumper: PRM/ Blingstar
Grab Bar: DG
Front Shocks: Works Triple Rates
Rear Shock: Banshee
Brake Pads: EBC
Brake Lines: braided Calipers: YFZ
Rotors F|R: Stock
Rims F|R: Douglas .190/ Stock
Tires F|R: GNCC/ Mud Lite
Body
Plastic: Stock/ cut fronts
Graphics|Seat Cover: Deadlast/ Stock
Number Backgrounds: Deadlast
Handguards: Powermadd
Bar Pad: Protaper
Fuel Tank: Stock
Skids plates: Plastic Engine skid/ Aluminum rear skid
Lighting: Stock
Engine|Drive System
Cylinder Head: FST Ported/ +1mm intake
Gaskets: Cometic
Piston: JE 85mm 10.5-1
Cam|Valves Springs: Web .440/ hd springs
Bore & Stroke: 85mm bore/stock
Displacement: 366cc
Carburetor: 36mm Sudco
Spark plug: NGK
Stator: Stock
Shifter: yz250
Air Filter|Box: GYT-R/ Outerwears
Header|Silencer: Powerbomb/ Pro Circuit/ Curtis Sparks
Clutch|Plates|Springs: Barnett
Gearing F|R: 14t/40t
Chain: EK Gold
CDI|Killswitch: Stock/ Alba
Cooling: Perma/ SPAL and shroud
Old Mar 1, 2012 | 11:11 AM
Raptor450's Avatar
Sweet! Is that a custom muffler? Curtis Sparks doesn't make them for a Warrior any more.
Also how do you like the a-arms? I had the same ASR arms on mine and when the heim joints got full of dirt and mud it was hard to steer.
Old Mar 1, 2012 | 11:28 AM
I got the exhaust off ebay and refurbished it because their so rare and great for power. I love the front end only complaints i have with the heims is their noisy and dont last as long as ball joints. I was doing a 446 for it but i got it because the rod bearing out and upon taking it apart i found it needed a new oil pump, rod, crank bearing and a new sleeve. So i just decided to keep it stock stroke with the good fst head for reliability
Old Mar 1, 2012 | 07:06 PM
95wolv's Avatar
Very sharp looking Warrior, much sportier looking than stock with the plastic trimmed and the decals. Great looking front end, must handle/ride a lot better than stock.
I would get some skid plates and a arm plates on that bad boy, dont want to mess up your investment with hit from a rock or stump.
Old Mar 1, 2012 | 07:46 PM
thanks ive got a belly and swingarm skid but you cant get skids for the +2 plus ive never really had a problem with them needing skids
Old Mar 1, 2012 | 11:05 PM
Raptor450's Avatar
Originally Posted by beastlywarrior228
I was doing a 446 for it but i got it because the rod bearing out. So i just decided to keep it stock stroke with the good fst head for reliability
Yeah I put the 446 in mine but I kept blowing the head gasket out. I think I finally got it right but then I sold it. The only good thing about the 446 was it was such a sleeper. I would pull up to the line and get laughed at - then leave highly modded 440EX's in my dust. Still couldn't beat stock YFZ450's but it was right there with 'em - not too shabby for an old Warrior engine! I had changed all my stuff over to a Raptor 350 frame & plastics - where the name came from - Raptor450!
Excellent choice to keep the 366 for the reliability.
Old Mar 2, 2012 | 09:55 AM
you have any more pics of your quad. i remember seeing a some a couple of years ago. i want to see what your exhaust looked like
Old Mar 2, 2012 | 01:45 PM
Raptor450's Avatar
Yeah I'll see if I have some more pics on my other computer when I get home. When I switched over to the Raptor 350 frame I had to get a new muffler cause the mounting is different on the Raptor. I ended up with a HMF slip-on and the factory header. I was disappointed I couldn't use the Sparks, but the HMF sounded almost as good and performance seemed about the same. I used the factory header because everyone I talked to said the factory Warrior header is oversized from the factory and just as good as any aftermarket pipe out there.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
