No Power
Old Apr 16, 2012 | 09:47 AM
DDeremo's Avatar
Default No Power
I have a 1996 250 Trail Boss that has no power. Runs like a spotted ape on flat ground but will not go over a 1" - 1.5" ledge from a stop. Normal or not normal for a 250? If not what might I start to look at to fix it?
Thanks
Old Apr 16, 2012 | 05:44 PM
95wolv's Avatar
Sounds like the clutch would be a good place to start, take the cover off and see where the belt is in the secondary, is it slightly above the lip? if not, you may need to shim the clutch or replace the belt. Also, it could just be dirty, try blowing it out with an air hose and spraying surfaces down with some brake cleaner. Then rev it up in neutral and see if the primary clutch grabs the belt and closes all the way, pulling the belt in, you could have sticky weights or worn springs in either the primary or the secondary.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
salixair
Nov 3, 2015 08:25 AM
scorpiankill
Sep 10, 2015 09:14 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
