Return to Idle - Moto4
Purchased a 1990 Moto4 80cc for my six year old and spent a few nights getting it running (Battery, carb cleaning).
Started it up last night and it ran solid it did however not return to idle it would run at a high RPM and eventaully idle. I was thinking of just buying a rebuild kit but I don't know it I need it.
Could it just be a cleaning of the throttle body slide? or something else?
Also make sure the slide is dropping all the way down when throttle is released, even a tiny gap will raise rpms until it falls back down, could be a burr on the slide, a sticky throttle cable (get a cable luber and flush it out) or a bad/weak slide spring. make sure the linkage the throttle hooks up to moves freely and snaps back to close when released. Older carbs usually have a little moisture corroision on the internals that will gum up shafts and linkages and prevent smooth movement.
