what is the best hot cam for a 2003 warrior?
Old Jun 19, 2012 | 09:22 PM
atvboy4ever's Avatar
Default what is the best hot cam for a 2003 warrior?
Im looking to buy a hot cam for my warrior, it has fmf power bomb header, fmf power core exhaust, high comp piston, and best of all, NOS , im mainy looking for more top speed, or should i re gear it instead of a cam.
Old Jun 20, 2012 | 01:48 PM
Raptor450's Avatar
A cam is not really going to give you top speed, it will just allow the engine to rev faster and higher and allow the engine to pull taller gearing better. If all you need is more speed, then I would change the sprockets. A bigger front sprocket and/or a smaller rear sprocket will give more top speed.
As for cams, the Webcam 84 grind are better for the Warriors, especially since u have a higher compression piston. You do have to run upgraded valve springs for that cam. If you're stuck on Hotcams, go with the cam that has the highest lift and duration, which will probably be the highest stage they offer (stage 3 maybe?). If I remember correctly the Webcam 84 grind has more lift and duration than even the biggest Hotcam.
Old Jun 20, 2012 | 10:30 PM
beastlywarrior228's Avatar
Web or megacycle with the .390 lift
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
greg86hd
Sep 16, 2015 12:32 AM
Hw00d
Sep 10, 2015 08:53 AM
