please help. only runs with choke.
Old Jul 15, 2012 | 02:03 PM
jesussaves's Avatar
Default please help. only runs with choke.
I am new to the site and need some help. I bought my son a 2005 polaris predator 90cc 2 stroke. It had been sitting a while so I cleaned the carb and it was good to go. We rode for 15 or 20 min. The next day it wouldnt run so I cleaned the carb again, the plug and filter looked good, and i checked the compression and it was 90 psi. (That is good, I think?) Now it runs with the choke on, but dies when I put choke off. (also will not idle with choke off, but will when choke is on) while it is running I sprayed carb cleaner trying to see if it is sucking air and it does'nt apperar to be. I also checked and cleaned the reed valves. When it is moving you can take choke off and ride but when you stop or rpms come down it cuts off, And when you go wide open throttle and let off and hit the throttle again it backfires. What else could it be. please help. Thanks in advance.
Old Jul 15, 2012 | 03:23 PM
Sounds like you've still either have a carb problem(trash stopping up the jets,needle valve sticking not allowing enough fuel in the carb bowl,etc) or a fuel supply problem(kinked fuel line, fuel valve faulty),if it takes having the choke on to run properly. 90 psi beginning to be a little low also. Shows service limit to be 115 psi on the older manual I have,but this is the same engine. OPT
Old Jul 15, 2012 | 03:37 PM
Rypper1's Avatar
JS,
Glad you found this site. I was going to pm you about it on the Polaris site. Check the things OPT said, he knows his stuff.
Old Jul 15, 2012 | 03:45 PM
jesussaves's Avatar
ok thanks for the feedback. I did notice the little metal piece on the float was bent a little, but I didnt think that could make it act like it is sucking air and only run on choke. I will clean and check the float again in a day or two. Also, Was the compression good ? (90 ) Thanks again.
Old Jul 15, 2012 | 03:51 PM
90 is on the lower side.The older manual I have shows 115 to be the service limit,but the engines are the same. OPT
Old Jul 19, 2012 | 10:05 PM
jesussaves's Avatar
Smile
Ok guys, I hate to admit it but it was still a dirty carb. I went and cleans gas tank, petcock and carb. Found that the small jet was clogged again. runs great now. Thanks for all the help. Does anyone know where I can buy a new oil warning light. The previous owner premixed the gas and broke the oil light. Thanks again
Old Jul 19, 2012 | 10:09 PM
A lot of people clean "at and around" carbs and don't realize they need to be taken apart. Look here and search up your model for parts. Browse
OPT
Old Jul 19, 2012 | 10:25 PM
jesussaves's Avatar
Thanks OPT. I found it. It sure is nice having someone who knows their stuff.
chinkapin
Jul 14, 2016 06:58 AM
Dame0927
Oct 29, 2015 10:13 PM
Ty Speece
Jul 2, 2015 04:59 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
