sportsman 700 no fire
Old Aug 23, 2012 | 10:28 PM
cajun79's Avatar
Default sportsman 700 no fire
was riding my 2003 sportsman 700 the other day ,it backfired died ,doesnt have fire,,put new plugs,had the coil checked ,had one guy tell me to check the flywheel but i dont know what the bolt size is yet ,has anyone ran into this problem before ,please someone lead me in the right direction
Old Aug 23, 2012 | 11:55 PM
Welcome to the forum! You can check out all the posts on the early 600 and 700 Ducati ignition problems and a lot are just like yours! The bolts in the flywheel are 8mm and you need 3 long ones about 3 to 3 1/2 inches long and a good steering wheel puller along with a good propane torch to heat the center area up on the flywheel while you have pressure on the puller. Better if you have an air impact,hard to do without it. The main problem is the Ducati ignition will fail and there is a complete updated Kokusan kit #2202602 which includes a new flywheel,stator,cdi,coil,regulator/rectifier,jumper wires and instructions. Cycle Parts Warehouse or Cheap Cycle Parts are about the cheapest online. About $450 for the kit. Not what you want to hear I know,but just check all the prior posts on this problem(or simply Google "Polaris 700 atv ignition problems") for a better understanding.This was a problem that affected all 600 and 700 models from 2002 to early 2004. OPT
Old Aug 24, 2012 | 07:55 AM
cajun79's Avatar
thanks for the info ,i had read that before and was hoping that wasnt the case but might as well try that before tearing down the engine,that is what i thought i was gonna have to do , didnt know if something broke inside
Jmuddin284
Jan 19, 2026 07:16 AM
Cole Hadden
Jun 15, 2025 09:05 AM
COFatboy
May 2, 2020 12:06 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
toonces
Jul 24, 2015 09:03 AM
