2004 Big Bear Rear Shock Bad?
Old Sep 11, 2012 | 06:50 PM
Dave1's Avatar
Trapper Dave
Default 2004 Big Bear Rear Shock Bad?
I have a 2004 Big Bear 400 4WD. The rear shock will no longer support a heavy load on the rear rack, squats in the rear end under load, and seems to bottom out the shock when loaded heavy.
Is the shock bad? Do you rebuild or replace them? How much for a good heavy duty shock?
Thanks, Dave
Old Sep 19, 2012 | 08:42 AM
Dave1's Avatar
Trapper Dave
I checked around on the Internet and at some of the online parts suppliers I found the OEM replacement rear shock is available for about $130 (cheapest).
Is there a better than OEM, heavier duty, higher weight carrying capacity shock available?
Thanks, Dave
Old Sep 19, 2012 | 04:54 PM
geoman's Avatar
The spring generally holds the load not the shock. How much of a load are you putting on the back end of it?
You could check with the aftermarket shock companies like Elka, works, etc. and they can build you a heavier duty shock and spring combo but your going to pay good money for it. Your other option is to have your existing shock revalved and sprung for a heavier weight, this will be cheaper than having a new one but still more expensive than buying a new OEM shock.
Bratman2
Aug 6, 2022 01:42 AM
07Redrider400
Jul 25, 2015 05:31 PM
Peter_
Jul 18, 2015 07:06 AM
cSchwartz
Jul 9, 2015 02:40 PM
Jkfx400P
Jul 6, 2015 10:04 AM
