400ex timing
Old Oct 10, 2012 | 06:15 PM
savage5480's Avatar
Default 400ex timing
When you set the timing the lobes on the cam are down and you can rotate back around then the lobes are back up. How can you tell which one to set to
Old Oct 10, 2012 | 07:46 PM
savage5480's Avatar
I had it where piston was top dead center and the lobes on cam were down. Is that correct?
Old Oct 10, 2012 | 08:05 PM
jgar's Avatar
You can install the cam with the lobes up or down. Depends on how you took it apart. Lobes up is TDC on the exhaust stroke and lobes down is TDC on the compression stroke.
I would turn the crank counter clockwise and line up the T mark on the flywheel. Just like you would if you were adjusting the valves. This will put the motor at TDC on the compression stroke. Then install the cam with the lobes down.
Reactant
Mar 30, 2022 02:08 AM
slowgsxr97
Mar 18, 2022 03:40 AM
95wolv
Jul 21, 2015 12:25 PM
95wolv
Jul 17, 2015 08:13 PM
yambam13
Jul 4, 2015 01:49 PM
