Wrench image on dash
Old Oct 25, 2012 | 10:54 AM
Johnnyhorsepower's Avatar
Default Wrench image on dash
I have a 2009 Sportsman 500 HO and on the dash i have had the wrench image that won't go away. I do all my own maintenance so i was wondering if this automatically comes on for the 100 service ? This was about when the image first appeared. Does anyone know if this is true and how can i reset it so it does not show up on the dash?
Thanks -john
Old Oct 25, 2012 | 11:04 AM
DogRunner2's Avatar
Its the maintenance light. Should be covered in the manual.
Old Oct 25, 2012 | 01:11 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
what ever you do... DO NOT CALL THE POLARIS DEALER AND ASK THEM!
Old Oct 25, 2012 | 01:45 PM
Have the atv in neutral. Hold the overide/toggle button down then turn the key on. The diagnostic display will come on. Toggle until you get to the wrench symbol. You can set it to OFF and no hours will be counted on the service wrench. If you want to set a certain hour service interval, hold the Toggle button down until the wrench symbol flashes,let off the button, press down again and will count up on hours.You can hold the toggle button down for fast counting OR intermittently push the button for a slow hour increase. Stop at the hours setting you want. If you go past,just push down again and will go to 250 hours and then start back at 0. Stop at desired hours,wait until wrench stops flashing then turn the key off and the wrench won't flash again until the hours count down. OPT
vandammages@gmail.com
Aug 20, 2020 11:50 AM
salixair
Nov 3, 2015 08:25 AM
Ryan Downey
Exotic and Modified Quads
Sep 29, 2015 09:31 AM
exmotocrosser
Sep 26, 2015 08:18 AM
woodthings
Sep 25, 2015 05:58 PM
