R still doesn't idle
Old Mar 22, 2001 | 07:09 PM
400exalltheway's Avatar
hey agian, i still can't get me R to idle. i have a 155 man, 52 pilot, 4 notch, and almost 2 turns out on the airscrew. i have a pipe and no airbox with K&N filter any more suggestion. the book said thepilot jet was 48 stock but most people told me to go to a 50-52, should i try a 48 pilot
Old Mar 22, 2001 | 09:49 PM
Shift's Avatar
I have a 48 pilot in mine and it runs great but I'm thinking about switching to a 58 like FMF suggests. Try turning the idle adjustment screw (choke ***) out ALOT. I had the same problem but I turned it so much that it looked like it was choked all the time but it wasnt and it idles and runs fine now.
Old Mar 23, 2001 | 07:43 AM
i'll try that and let you know tonite
Old Mar 23, 2001 | 09:20 AM
BIRDofPREY's Avatar
Mine was not idling either when I bought it and I thought it was supposed to do that since it was professionally raced by a pro (maybe a rule or something to shut off when not on the bike?). Anyway, we had the carb apart and found a little trash, cleaned it and now it idles fine. Maybe just a fluke?
Old Mar 23, 2001 | 11:52 AM
retro's Avatar
A 58 pilot! That seems huge for the mods you have listed!
ERIC
Old Mar 23, 2001 | 03:01 PM
Berch's Avatar
first thing you should do is take the carb off the bike and clean it inside and out you may have a small piece of dirt in the carb or a bent needle
If you dont feel comfortable bring it to a shop.
after it is all cleaned out take some carb cleaner and spray in all the nicks and crannies(holes and other places that may block any flow)
If you are running a 36 carb you want your air screw out between 1 and 2 turns out, 155-165 depending on modifications and temp. 50-55. Needle should be in the center. Call a dealer or aftermarket for new needle if needed.
also clean air filter
Old Mar 25, 2001 | 07:42 AM
ok i put the 52 pilot jet in and that seemed to help alot, it won't idle yet but it tries to, i'm going to try a 48 which is stock really soon. i'll let you know then
Old Mar 25, 2001 | 09:04 AM
DS650DAVE's Avatar
Have you cleaned the carb?I definietly would. Does choke button stay up,when pulled up?I had an R that did not want to idle, gave up trying to makeb it, bought a completely new choke & then it would idle,try a new one maybe,costs about $30.00.
Old Mar 25, 2001 | 09:10 AM
yeah i cleaned it completely out. i'm 99% sure its the jetting b/c i tried 2 different carb assemblies and nothing. when i put he 52 pilot in it sounded alot better so i think when i go to a 48 it will idle.
Old Mar 25, 2001 | 06:51 PM
DS650DAVE's Avatar
It might lean with that low a jet,pipe&k&n filter.Do a "plug check",after rejetting.
Divergent12
Aug 19, 2023 05:26 AM
Cummins Driver
Sep 11, 2019 01:22 PM
cdoren
Aug 16, 2015 11:22 PM
Roadglider09
1) Engine problems..
Jul 30, 2015 09:21 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
