2005 Polaris 500 Ho speedo problem
First check that the hall effect sensor is plugged into the speedometer.If the speedometer doesn't work and mileage doesn't accumulate, the hall effect sensor located on the caliper has usually shorted out. You can clean this area up to see if dirt/mud may be blocking the sensor. If doesn't help then replace it.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse Item #21
OPT
OPT
hoopduerr
Jun 10, 2015 03:00 PM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
May 27, 2015 11:15 AM
