335 idle problem
Old Nov 19, 2012 | 04:06 PM
skeets44's Avatar
Default 335 idle problem
so was riding everything fine. we were riding the new lost trails in pa. If you know it is rocky to put litely. it started to run high as we were riding after we stopped first wouldnt go into gear at all. took shifter off dropped back in was fine. The idle was hi so high couldnt but into gear without grinding. Had to start in gear. will go about 15 mph w/o throttle. next day started right up still running hi about 4 hours later wont start at all. carb was cleaned out air filters changed. any ideas?
Old Nov 19, 2012 | 04:44 PM
Check for any throttle cable binding and that you have at least 1/8" slack at the thumb throttle. If this checks out it could be a diaphragm spring, slide needle or carb slide problem.Also could be as simple as trying to lower the idle screw under the carb. OPT
Old Nov 20, 2012 | 05:21 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
maybe the dia. spring is hanging up or broke if the other checks out. seems like it would be the throttle cable caught on something and holding the idle up.
Old Nov 21, 2012 | 06:44 AM
skeets44's Avatar
Default thanks
so i was ridding my son and he was holding the inside handle bar and had his hand on the adjuster screw on the cable...duhhhhhh but i dint even know it was there... was not fun comming down the mountain. thanks for the help....
Old Nov 21, 2012 | 08:15 AM
Dangerous! If you must let kids ride at least keep em on the back with a helmet on! I've seen and heard too many horror stories over the years. OPT
Old Nov 22, 2012 | 03:54 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
glad it was an easy fix
KimSJoh
14
Jul 18, 2015 07:20 PM
ranvette
Jul 12, 2015 06:34 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
MNatv89
Jul 7, 2015 11:36 AM
