oil change
Old Nov 23, 2012 | 11:47 AM
hkc3's Avatar
Default oil change
I've had a polaris scrambler 500 for a few months and am finally doing service, checking anti-freese, lube etc., I was getting ready to change the oil and I found the drain plug but not a fill plug, it has a reservior under the driver side fender, but there still should be a fill plug, I know my eyesight aint great but where is it hiding???
Old Nov 23, 2012 | 02:18 PM
TLC's Avatar
TLC
The big screw plug with the dipstick to check the oil level is where you put the new oil in (quarts). Its a dry sump motor not a wet sump motor so the oil is stored in a separate oil tank not in the motor itself.
Old Nov 23, 2012 | 03:06 PM
hkc3's Avatar
Dry sump system on a 4wheeler, I had no idea, doesn't seem like the reservoir holds much.
Old Nov 23, 2012 | 03:08 PM
hkc3's Avatar
so I just need to drain the reservoir, then why do I have a drain plug on the motor. I need to get a manual.
Old Nov 23, 2012 | 03:19 PM
TLC's Avatar
TLC
All I do is drain the oil tank, then start the motor and let it idle for 20 seconds to pump the remaining 1/2 cup of oil in the crankcase of the motor into the oil tank.
Re install oil tank drain plug and add 2 quarts of oil. With a oil filter change as well.
Old Nov 23, 2012 | 03:21 PM
hkc3's Avatar
Tried to get a manual from gh1971 thread but it says info not there, anyone have a manual for a 99scrambler 500 4x4, thanx
Old Nov 23, 2012 | 03:24 PM
hkc3's Avatar
2quarts, damn my reservoir can't hold that much, Ill see what I get out of it', thanks! I appreciate the help.
Old Nov 23, 2012 | 04:28 PM
The total oil quantity is two quarts like TLC said! The engine itself ( the sump,plus whats in the upper end at any time is no more than 10-12 ounces max! With the engine cold, the sump only holds approximately 8 ounces after all oil has finished draining back into the oil tank,plus what's in the oil filter) the rest is is the oil tank.Dry sumps have a couple advantages over wet sump engines. Less oil in the engine which enables the engine to produce more power with less resistance,plus the oil temperature is a little cooler because of the air circulating around the remote tank. When you change oil make sure you let it run for 4 to 5 minutes and let set a couple minutes to get an accurate level on the dipstick when screwed all the way down. Drain the way TLC suggested,just drain the remote tank,leave the old oil filter on,after the tank drains crank for 10-20 seconds and then kill the engine. The sump oil will drain into then out of the remote tank,the rest of the old oil is in the filter. OPT
Old Nov 23, 2012 | 05:46 PM
hkc3's Avatar
Thanks guys.
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Alex G.
Sep 11, 2017 11:38 PM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
