Need help with trailer tie down
Old Nov 24, 2012 | 10:02 PM
gmrgrl2600's Avatar
Default Need help with trailer tie down
Just bought a 2013 FrourTrax Foreman Rubicon yesterday along with a 5 x 8 trailer to pull behind my Jeep Wrangler. I bought a new set of ratchet straps and after some frustration with the straps; I was able to tie it down to the trailer today for my first trail ride. It stayed on the trailer fine during the ride to the trails. However, when I loaded it back on the trailer after a day of glorious fun, I had major difficulties with the straps, and they are all in a knotted useless mess now. This has brought me to several questions:
1. What other methods can I use to tie the atv to the trailer besides ratchet straps?
2. I'm thinking of getting the Kolpin Trailer Dog Atv Tie Down(also known as the LA Guard Dog). The floor of my trailer is metal; and I wanted to make sure the trailer dog will still work?
3. I was also wondering if I should consider wheel chocks, and if someone could recommend the best ones?
4. If I do go with ratchet straps, which ones are the best and easiest to use?
5. Could I just use chains with a lock of some type to tie it down?
Thanks in advance for your much needed help!
Old Nov 25, 2012 | 06:53 AM
jgar's Avatar
Ratchet straps are the only way to go. Chains are overkill for a quad and they will scratch and bend parts when you use a binder to tighten them up. Take 5 min to roll up the ratchet straps and learn how to use them.
Old Nov 25, 2012 | 09:56 AM
TacticalRedneckofKentucky's Avatar
Yep, ratchet straps are the best thing for me. I bought 2 at tractor supply i just press a button and they will let you unloosen them, press it again and they pull tight, finish tightening with the ratchet. But these are just cheapys dont know if they are to strong, i just use them when i put my quad in the truck bed.
Wheel chocks- i just put mine in gear and tap the starter button to get it up to the rail of the trailer.
For hd straps i went to lowes or home depot and picked up 2 or 3 gigantic ratchet straps for $15 each, cut off all the excess strap, took a match to the end, and works perfect, some of those chinxy ratchet straps are hard to get undone, but these work fine.
Old Nov 25, 2012 | 10:28 AM
DogRunner2's Avatar
Agree with jgar, learn how to use ratchet straps.
Old Nov 26, 2012 | 07:49 PM
jcdc04atv's Avatar
Ratchet straps are the most cost effective method of anchoring your atv down. Before installing, make sure they are straight (not twisted) and all knots have been untied before using them.
Old Nov 26, 2012 | 07:52 PM
gmrgrl2600's Avatar
Thanks everyone - I purchased a new set of straps today and watched the video above!
Old Nov 26, 2012 | 08:01 PM
jgar's Avatar
I know grown men (construction workers) who cant figure out ratchet straps.
Old Nov 26, 2012 | 08:06 PM
gmrgrl2600's Avatar
Then I don't feel so bad being a girl and all
Old Nov 26, 2012 | 08:19 PM
jgar's Avatar
Old Nov 26, 2012 | 08:59 PM
95wolv's Avatar
This spring I bought a set of spring loaded ratchet straps from Menards, 25 bucks for a set of 4, they pull the slack in under spring tension, you hook one end, open the ratchet handle, pull it out to hook the other end, and then a few ratchets of the handle and its tight, no extra strap flapping in the wind, no threading the end and lining up the slots. Just hook and ratchet. Best money I ever spent.
Johnny Mac
60
Dec 14, 2019 06:13 PM
dannytas
Sep 26, 2017 06:31 PM
badgerboy1
Sep 26, 2017 06:11 PM
bigred20653
Oct 2, 2015 10:05 AM
caveeagle
Sep 19, 2015 01:20 PM
