2006 Sportsman 800 Lower A-arm removal
I just got back from a hunting trip up north a noticed that the lower inside front bolt on lower right rear a-arm fell out and bent downward. I removed the wheel, unbolted the bottom of shock and removed the outer a-arm bolts. The remaining bolt on the inside of the a-arm (rear side) will not come out, it only spins on the threaded bushing on the inside of the a-arm. How do I remove ths bolt? Do you guys think the a-arm is bent? I this a commom problem. Thanks.
You can get one side out, but not the other side, right? This is what I do. I take one side out and get a not to put on the bolt, then i just screw the bolt back in by hand just a couple threads. I then use the nut as a jam nut and hold the head of the bolt with a wrench and tighten the nut down with another. I then take the bolt out of the other side, then untjghten the jam nut and take the bolt out by hand.
Frisky2050
Apr 9, 2020 11:19 AM
