Scrambler 4X4`s using ITP wheel kits
Old Mar 22, 2001 | 11:27 PM
Mumbles's Avatar
Will ITP wheel kits with Holeshot XCT tires work on the 4X4 Scramblers. I`m wondering if the tires are going to bind when in 4 wheel drive.
Old Mar 23, 2001 | 01:22 AM
JWC's Avatar
JWC
I have 23x7x10-22x11x10 HoleShots XCT with a one tooth larger front sprocket(shaft driven front). P/N 3233538 with no problems. No trouble bending the front wheels any more.
John
Old Mar 23, 2001 | 01:24 AM
Xplor's Avatar
Bending the front wheels???
Old Mar 23, 2001 | 01:34 AM
JWC's Avatar
JWC
I was talking about the stock aluminum rims and tires even with 15 lbs. of air Bending.
Old Mar 23, 2001 | 02:15 AM
Lurch77's Avatar
Like JWC did, just keep the ratio between the front and rear tires the same and you will not have a problem.
Old Mar 23, 2001 | 06:20 AM
MilleniumScr500's Avatar
JWC
Why would you go up a tooth on your front sprocket when those tires you mentioned were the stock sizes it seems like you are throwing the ratio off now.
Just curious
Old Mar 23, 2001 | 08:20 AM
Mumbles's Avatar
I`m not worried about the tires "bending", I`m wondering if the ratios between the front and rear drives will get messed up and cause "binding". I looked at one of the ITP wheel kits with Holeshot XCT tires mounted on the rims, and the front tires look a lot taller than the rear ones.
Old Mar 24, 2001 | 02:20 PM
JWC's Avatar
JWC
I went with one tooth bigger to try to kill some of the wheeles down, no luck and add some MPH. (guess I need a loger swingarm) I was told you could change gearing around a little (not for sure how much) or go a couple inches taller tires from front to rear. I would like to try a 34 tooth on the rear from a 36. Not sure if its to much of a change. With the 14 on front.
99 4x4 Scrambler 400
Big Bore 86.5-not ported just cleaned up
RCR Pipe
39 Kehin-no air box
HPD Red-Yellow w/ 58 weights
Violet on the rear w/ 44/36 Helix
Old Mar 25, 2001 | 08:54 PM
ScrambledKiwi's Avatar
23-7-10 & 22-11-10 are stock sizes.
I have been running the ITP Holeshots on ITP T9 wheels since they released the XCT's and no binding problems. The work great in all my types of riding. Fast trail, a bit of racing, muddy trail, and grass farm and farm tracks. They are not the hot ticket in sand though - To square and aggressive.
Old Mar 25, 2001 | 09:14 PM
Mumbles's Avatar
Thanks for the info
scram5050
Aug 19, 2015 02:19 AM
mitchxc700
Aug 10, 2015 09:26 PM
1000gade
Aug 9, 2015 03:34 PM
toonces
Aug 5, 2015 05:55 PM
maxjung
Jul 13, 2015 05:11 PM
