Electrical meltdown..Literally
Old Dec 28, 2012 | 08:38 PM
Sleddingfarmer's Avatar
Default Electrical meltdown..Literally
Well I was attempting to re-wire my handwarmers tonight, but was met with some brief scary failure. My plan was to wire them from the battery to an on/off switch at the pod, however as soon as I flipped the switch I was met with melted wires!!
The warmers are the Symtec ones.
Here's what I did..
Positive:
Ran a wire from the battery to the toggle
Then had red power wire from warmer to toggle (previously wired to Red/black aux wire coming from the key) However I didn't realize til after meltdown, that I had forgot to put this wire to the toggle... D'oh!
Neg:
Wire from battery to toggle
ground wire from warmer to toggle
The second I flipped the toggle the wires melted from battery to toggle.
I used 16gauge wire and a single pole, single throw 20amp, 125-277vac switch .
Crap,are there different switches for AC and DC?
So let me have it, where did I go wrong...
Old Dec 28, 2012 | 09:01 PM
See if this helps.Ones I installed had a low and high setting. http://www.google.com/url?sa=t&rct=j...,d.aWM&cad=rja
OPT
Old Dec 28, 2012 | 09:41 PM
Mine are the Winter pak ones with 5 heat settings... There's only a power and ground wire to hook up...
Symtec ATV Winter Pack - Shade Tree Powersports
Old Dec 29, 2012 | 09:12 AM
jeepcrazy's Avatar
you should not run the ground to the toggle.12 v through the switch to the warmers.straight to ground from warmers.
Old Dec 29, 2012 | 11:21 AM
Yep, I kept thinking it over and over and finally realized my screw up this morning... Everything works now, glad I didn't fry anything else, thanks for help!!
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Sw00p
Sep 24, 2015 02:50 PM
