Need Help!
HI i have a 150cc Chinese make atv and took apart the carb to give it a good cleaning, before taking it apart i did not look where at the tubes went form it, i need to know if any of them go somewhere or if they are just vents. First one is coming out of the carb bole. the second one it coming out of the air intake manifold. the third one its coming from the top of the carb and wrapping around the spring cover. plz help
Maybe this will help.
Google Image Result for http://www.scootusa.com/152QMI_carb/connections-02.jpg
Correctimando Ron, i had this same problem with mine, spent hours trying to figure out where they all went, the vacuum like goes to the intake manifold, fuel line goes through a fuel filter then to tank and sometimes a overflow tube just hangs there and same with the drain.
