Need Help!
Old 12-29-2012, 05:01 PM
atv150cc's Avatar
Exclamation Need Help!
HI i have a 150cc Chinese make atv and took apart the carb to give it a good cleaning, before taking it apart i did not look where at the tubes went form it, i need to know if any of them go somewhere or if they are just vents. First one is coming out of the carb bole. the second one it coming out of the air intake manifold. the third one its coming from the top of the carb and wrapping around the spring cover. plz help
Old 12-29-2012, 07:59 PM
LynnEdwards's Avatar
Electrical Expert
Is this a GY6 engine?
If so do a google search for:
"gy6 vacuum line diagram"
and look at the pictures. I bet this solves your problem...
Old 12-29-2012, 08:55 PM
atv150cc's Avatar
How do you tell im kind of new to atvs iv had it for years and only drove it like 20-30 times
Old 12-29-2012, 09:33 PM
RonV's Avatar
The one coming off the carb bowl just hangs there. It's the float drain. I believe the one on top is a vaccum line. Is the third one the for the fuel line?
Maybe this will help.
Google Image Result for http://www.scootusa.com/152QMI_carb/connections-02.jpg
Old 01-04-2013, 09:46 AM
max1298's Avatar
Correctimando Ron, i had this same problem with mine, spent hours trying to figure out where they all went, the vacuum like goes to the intake manifold, fuel line goes through a fuel filter then to tank and sometimes a overflow tube just hangs there and same with the drain.
