08 800efi RZR shift cable problem
Old Jan 16, 2013 | 05:11 AM
Tpl1963's Avatar
Default 08 800efi RZR shift cable problem
Having trouble adjusting cable for shifter. This is causing awd switch to not work right and problems period.
Need help!!
Old Jan 16, 2013 | 11:42 AM
Didn't work on too many Razrs,(bad knees)but there is a cable adjuster either mounted on the cable support bracket on the transmission OR the cable can be adjusted by removing the clevis pin at the transmission lever,remove the cable and there should be an adjuster to take up any slack. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
OPT
GregM
Mar 6, 2018 06:53 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
timster911
Jul 13, 2015 01:57 PM
sara durrant
Jul 6, 2015 05:32 PM
