need help progressive springs change
Old Mar 23, 2001 | 08:49 PM
sportsman500nc's Avatar
I was working on changing the progressive springs, and stupid me let the bottom fall down to low and the spline has fell out the cv, how do I get it back in? Some one please help me.
Old Mar 23, 2001 | 10:44 PM
anyone?
Old Mar 24, 2001 | 03:30 PM
MilleniumScr500's Avatar
I wish i could help you out but I have no Idea I do not own a Sportsman.
maybe jacking it up and guiding it in while you are compressing the suspension.
Like I said I have no Idea what so ever Sorry
Old Mar 24, 2001 | 03:54 PM
cokeisit's Avatar
i did the same thing you have to cut the outer boot clamp. make sure ***** are in place, slide shaft back in then put a new boot clamp on.
Old Mar 24, 2001 | 09:26 PM
Toad1167's Avatar
If you can raise the strut back up slowly and guide the shaft back in by slightly turning the hub it should line up and go back in.Hope this helps.
Old Mar 25, 2001 | 08:33 AM
stew's Avatar
I just did the same thing installing me HL lift kit. cokeisit has the same answer I do. Remove the clamps carefully, (so you can take them to somewhere like NAPA to match them up with new ones) slide the boot back toward the differential,now get real greasy and line the shaft up on the cv joint, and slide it together. You might want to get the new clamps before you assemble. Some clamps can not come apart, so you might need to slide it over the shaft before you assemble. There is just enough room to crimp the clamp from behind the brake caliper. I'm still trying to get my hands clean. Good luck, its not too bad.
Divergent12
Dec 30, 2017 08:33 PM
merryman
Jan 19, 2016 04:29 AM
Polarisman1123
Aug 13, 2015 08:13 AM
ghost civic
Jul 27, 2015 03:15 AM
Mphillips
Jul 2, 2015 07:20 PM
