12's on front
Old Mar 23, 2001 | 09:48 PM
zrt1000's Avatar
I just picked up the 01 500 manual to replace the one that got stolen(no ins.), and I am going to start putting the goodies on it and was wondering if anybody has put 12" wide tires on the front? I will either go with the 27" Mudbugs again (1500 hard miles on them with min. wear) or 28" mudzillas... Thanks Bill
Old Mar 24, 2001 | 12:59 AM
BONER's Avatar
Might want to update your signature.
I do not recomend the 12" wide fronts to you. I don't think it would be worth it for you to increase the steering effort like that. You can run them with no lift or spacers with a VERY VERY slight rub that is almost unnoticeable if you do choose to run them tho.
Old Mar 24, 2001 | 07:02 AM
Andy Bassham's Avatar
If I were buying tires today, I would get 28" Mudzillas. 8" on the front for easy steering and 12" on rear for max traction. If Claws came in a 28" tire, I would get them. The mudzilla really looks like a good tire to me, and 28" would be sweet.
Old Mar 24, 2001 | 08:34 AM
zrt1000's Avatar
Thanks .. I will update that ...
The 28" will go on with no lift? The 27" only hit when I jumped the bike. How much heavier are the 28" than the 27"? And you guys have been using stock rims for this? ... thanks ..Bill
Old Mar 24, 2001 | 11:13 AM
Win3855's Avatar
How do you like the Electrix shift? Work well, fit nice?
Old Mar 24, 2001 | 02:23 PM
cowboy's Avatar
Yeah, your stock rims will work fine. I've got the 27" Bi/Tri combo on the stock AC rims, they fit great. The only time you'd need to buy aftermarket rims would be if you wanted two sets-one for stockers in the summer time, and one for your heavier mud tires in fall and spring. Oh, the 'Claws are 9.75 wide up front, and 12 wide in the rear-fyi
Old Mar 24, 2001 | 07:01 PM
BONER's Avatar
here is what Maxxis has to say about there tires:
28x8= 29 lbs
28x10= 35.6 lbs
28x12= 41.6 lbs
27x10= 23.7 lbs
27x12= 28.6 lbs
26x10= 24.7 lbs
26x12= 28.4 lbs
Old Mar 24, 2001 | 07:46 PM
zrt1000's Avatar
I am worried about putting 2 different width tires on the same width rims, That would have to make them different hights which on hard pack or pavment that would be like running 2 different gear ratios and sooner or later will cause damage to the differentials or the tranny. Anybody say no ???
The electrix shift works well when it works, They (Cycle Country) are having problems with the linkage on the cats and are working on a new design and should have it ready in May or June.. The company is great,If you have any problems they send the repair parts right out..
The 28" tires are 10+ pounds heavier than the 27'show much of a difference do you think that will make on the bike ? ...., Bill
Old Mar 24, 2001 | 10:05 PM
BONER's Avatar
I'll tell you when I get my Tri-Claws mounted back up on my cat with factory wheels.
About the widths, that can be adjusted with psi in the tires if you want to. I see no need for it though, I see TRX 300;s running the same size tires all around when they have different gear ratio's front to rear. So I don't see how it could hurt the cat.
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
