Need help with Scrambler 400 2x4 Please
Old Feb 9, 2013 | 01:52 PM
db6357's Avatar
Default Need help with Scrambler 400 2x4 Please
At the end of last summer I was out riding the scrambler and on the way home it lost alot of power when full throttle then when I came to a stop it shut off and hasn't started since then. I have been messing with it on and off over the last couple of months trying to figure it out and am at a loss.
When I tried to start it before it would just crank but would never turn over. It has spark, its getting fuel, I have changed the reeds, new spark plug, new spark plug boot and wire. I just replaced the stator but am not sure if it has to be lined up a certain way. Now when I try to start it, it just cranks and backfires.
Does anyone have any suggestions?
Old Feb 9, 2013 | 04:35 PM
What is the compression reading? OPT
Old Feb 9, 2013 | 06:40 PM
db6357's Avatar
I for some reason forgot to even check compression so I just went out and checked, 30 PSI.
Old Feb 9, 2013 | 06:47 PM
I think you found your problem! OPT
Old Feb 9, 2013 | 06:50 PM
db6357's Avatar
Yes I definitely did, Thanks
Old Apr 20, 2013 | 05:33 PM
db6357's Avatar
Well I am back, with pretty much the same problem of the scrambler not starting. Since my last post I have had the piston replaced with new gaskets, another new spark plug. The compression is now 130 but it still won't start. It will try, run for a few seconds then shut off. I think the oil to gas ratio is a little off, would that keep it from starting? I have tried adding more gas to the mix but still nothing. Any suggestions would be great, this is driving me insane!
Old Apr 20, 2013 | 07:10 PM
If you're sure the carb isn't the problem,another thing is crank seals. If you haven't replaced them,could be part of the problem? If you're premixing, 40-1 is the rate I'd use. If you're still using the oil pump it's preset from the factory at 50-1. You can just pull the front plate and see if the mark on the oil pump wheel lines up with the case mark.
Old Apr 28, 2013 | 11:11 AM
db6357's Avatar
I don't think the carb is the problem but I am not positive on how to check it for sure. I have put on the old carb to see if there is a difference but no luck. I was able to get it to start twice for about 45 secs then it shuts off, it mostly backfires alot! I am not using the oil pump. I replaced the throttle cable hoping that was the problem because it was an issue before. I am not familiar with the crank seals as I have not had to mess with them before. Now there is oil leaking somewhere around the exhaust as the jug is covered.
Old Apr 28, 2013 | 12:23 PM
Just swapping carbs may not help if both need cleaning/kits,etc. Here's a couple vids on your carb. Backfiring can be a simple carb problem, compression related,130 psi is a little low on a new bore job and piston on the 400,could be leaking crank seals (lean condition) or even an electrical problem. Start at one thing at a time and eliminate it as a problem! Recheck compression,clean the carb/replace the carb kit,pull the front clutch and replace the crank seal(most people neglect these) As far as oily exhaust,it's common with wear/vibration on the pipes over time,Malcolm Smith Racing products did have some good pipe sealant tape,but I can't find it anymore. You can use some hi temp silicone sealant at the pipe connections and see if it helps on the leaks.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
