Sportsman 500/600 Reverse Issues
Old Feb 10, 2013 | 10:00 PM
eightyhd's Avatar
Default Sportsman 500/600 Reverse Issues
Out quadding today and ran into an issue i never had before on my (2004) 600, and then my girlfriends (2004)500HO.
When engaged in reverse, and i gas on it, it goes, and stops, goes and stops, and even when on flat surface, i push the quad and then it seems to rev up and go.
Anyone know whats causing this?
Also i have the reverse override, what does that do?
Does it put it in Reverse 4wd??
Old Feb 11, 2013 | 02:01 AM
You have to push the yellow reverse over ride button if you go over about 2mph in reverse or the limiter will kick in. It has to be pushed to have full power in reverse and also to engage 4wd in reverse. This is just a safety device.
Old Feb 11, 2013 | 10:05 AM
eightyhd's Avatar
awesome! Thanks! Will give it a try next time
Old Feb 15, 2013 | 06:14 PM
eightyhd's Avatar
Worked like a charm!
But super scary, i dont think ill bypass the limiter.
Old Feb 15, 2013 | 11:02 PM
That's why they have a reverse limiter so people won't get hurt. Good safety device when they work properly as it makes you aware that you will have full power in reverse and you need to keep the front tires straight.
bzdok1234
30
Feb 23, 2016 01:55 PM
coldnorthpol
Jul 14, 2015 11:22 PM
Shifts
Jul 3, 2015 07:59 AM
bikedad3
Jul 2, 2015 02:15 AM
Fullblast
May 26, 2015 12:38 AM
